JD 4420 Feederhouse wear strip material?
LonM
I am doing some work on the feeder house and I noticed the wear strips that are welded in place on the top sheet and top of the frame are really worn down. Is there a kit available anywhere to repair this? I was thinking some thick poly would work well, but if that is not to be found, I would like to weld in new steel. Does anyone have experience with this sort of repair? Thanks for any help!
Lon
