Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Source for 8wide drive belt for thresher?
Charles Krammin
07-24-2014 06:36:52
8" X 100" flat drive belt for thresher gave out and need replacement. Flea bay no hits. suppliers no good hits. Manufactures nil.
Help?
Sawmill operators borrow and squirrel away find.
Charles Krammin SW MI
D beatty
07-29-2014 11:32:39
 Re: Source for 8wide drive belt for thresher? in reply to Charles Krammin, 07-24-2014 06:36:52
Have you tried Hit&Miss Enterprises out of Orwell,Ohio Phone (440)272-5335. They have all kinds of old style flat belts and in differant widths and lenghths.
Charles Krammin
07-29-2014 13:50:44
 Re: Source for 8wide drive belt for thresher? in reply to D beatty, 07-29-2014 11:32:39
Tried h & T. Only list up to 6"
Bought a good used belt on the side.
Thanks, Now working on lateral tears. Think I'll try drill hole in one side of lateral tear- Thread lacing hooks thru-clap shut on other side. Or "flat head rivets, with washer"- belt patch on outside. will take picture & post.
ih_bug
07-24-2014 10:59:30
use baler belting, I know there are places to get them made up endless . mennonites I think are doing it.the rubber grips better to. several sawmills/planers running them here.
1031D
07-24-2014 10:52:40
I've got an 8" by 100 or 125' just north of Chicago. It's hanging in the trusses of a 60' long barn doubled up and goes wall to wall. I've got several so I could sell one or two.
Charles Krammin
07-24-2014 13:02:22
 Re: Source for 8wide drive belt for thresher? in reply to 1031D, 07-24-2014 10:52:40
E mail me a Quote on one or both. Will pick up. Might even take ferry across "big pond". Small sawmill also in need of a belt. To see equipment in action, go to Larry Pio u-tube.
https://search.yahoo.com/search?p=larry+Pio+u-tube&type=2button&fr=ymyy-t-999 About 6 posts of me at Historic Charlton Park.
1031D
07-25-2014 08:38:23
 Re: Source for 8wide drive belt for thresher? in reply to Charles Krammin, 07-24-2014 13:02:22
Charles, there's no email listed for you. casevac14@tds dot net if your in SW MI I'm just around the bottom of the lake in about as close to SE corner of WI as I can get.
david from kansas
07-24-2014 08:14:52
Problem seems to be finding a long belt. Lots of shorter belts which were probably used on grinders, shellers, wood saws, etc. I have a couple in my shed but don't think any are 100'.
Charles Krammin
07-24-2014 08:56:47
 Re: Source for 8wide drive belt for thresher? in reply to david from kansas, 07-24-2014 08:14:52
Neighbor donated a 6" sheller belt about 20'. Could get by with as last resort. Holding out for wider-longer.
Grand Rapids belting or Sparks in GR next try.
Thanks for help.
casecollectorsc
07-24-2014 09:13:56
 Re: Source for 8wide drive belt for thresher? in reply to Charles Krammin, 07-24-2014 08:56:47
Can the belt be spliced?? Can be shorter and narrower and still work okay. I have some extras but am in E SD.
Charles Krammin
07-24-2014 09:41:49
 Re: Source for 8wide drive belt for thresher? in reply to casecollectorsc, 07-24-2014 09:13:56
Belt shot. Steamer stretched it to hard and backing came off. Finished running on strings. Need to now clean up on shafts. Looking at new and Quotes as old seem to be gone, and weak. Will run sheller belt if necessary.
Old elevator leg bucket belt might work.
