Yesterday's Tractor Co.
Shop Now View Cart
Re: Yer typical novice type questions...
Matt Griggs
07-24-2014 03:51:03
On the switch, "road" lights up 5 of your six lights on the cab, taillights and flashers, "field" lights up those same 5 plus grain tank and unloading auger light. The switch on your steering column turns on your "high" beam headlight which is your sixth light on top of cab. I believe it's the fourth light from the left sitting in seat. It's quite possible you just have a bad connection from the wires especially on the flashers and taillights. When harvesting at night th lights don't shine very much on the auger of your header, so I added 2 more lights on the bottom corner of my cab angled to each end of the header.
It's quite possible your reel speed switch and automatic reel speed will not work. If this is the case there is a way to adjust the speed on the solenoid on side of feeder house.
Dave H (MI)
07-24-2014 06:55:27
 Re: Yer typical novice type questions... in reply to Matt Griggs, 07-24-2014 03:51:03
Yes...I have more lights than I first said. I believe there is one on the grain tank also, but not working. The one light that works on the front top only lights when the high beam is on. I guess this is gonna be one of those old machines with a lot of little issues and (hopefully) nothing major. But the little ones will keep you chasing your tale right thru the first time on the field and probably for a year or two after that! I never thought the day would come when I would say that I liked to cut hay to relax. But all that equipment has been mine so many years that I have most of the wrinkles ironed out and those that do come up are usually a 5 minute fix.
