Yesterday's Tractor Co.
Shop Now View Cart
Re: 1660 CIH work lights
Dave H (MI)
07-23-2014 19:53:09
Going to have to scare up parts and repair manuals. Not easy on these 80's machines if you want originals. Most of the 1660 manuals are for the later machines after a certain serial number. I'll have to look for the solenoid. Was it up in the roof access or under the control panel? Don't know why they would need such a thing to be honest. Why not just direct connect the lights? The other thing that bothers me there is that I believe there are six of these lights across the front and one does work. Two in the back that I recall and one also works there. Shouldn't they all be on the same circuit?
Really thinking I need these lights. Then I can pick the corn in the dark when nobody can watch me work thru my learning curve. Not like when I planted it. That could have been embarrassing if they all weren't so busy with their own fields!
Eric in IL
07-24-2014 16:44:17
 Re: 1660 CIH work lights in reply to Dave H (MI), 07-23-2014 19:53:09
If I remember correctly, the solenoid causing my grief was the cab solenoid. If I would repeatedly switch the key off and on, I could get the remainder of the lights to work.
The solenoid is located to your right as you sit in the cab. You gain access by removing the panel on the right side of the cab. It is mounted to the rear wall of the cab.
