The header lift is not wanting to work on my L. This seems to be happening after the oil gets warmed up. I swapped coils and everything is clean plus a new wire going to the lift coil.
It works perfect then it will simply stop and not work again and this seems to happen once the oil is getting warmed up. The coil is getting power also when it stops working. I am thinking there is a seal or O ring problem or something inside the poppet assembly. I am thinking about replacing the O rings and maybe the seat. Am I looking at this wrong??
