The master valve on the secondary valve unit has went to leaking very bad. The auger swing, reel height and I think reel speed were giving me issues with burning fuses I noticed this problem at the same time. I run all new wires and seem to have the fuse problem fixed but none of these functions work at all. I have a service manual.
Tomorrow I am going to order all new O rings. I had it apart and replaced the O ring that goes up into the valve body and it leaks as bad or worse.
The O ring seems too big around so I finally just pushed it in as best as I could and put the assembly together. What did I do wrong on the O ring assembly? I did remove the old one.
