TractorLinks.com
Re: Gleaner L hyd valve
gbs
06-10-2014 19:57:12
you probably damaged the o-ring you replaced being it wasn't the right size ,sometimes that will work depending on application best to get the correct one btdt
R Wyler
06-10-2014 20:02:27
 Re: Gleaner L hyd valve in reply to gbs, 06-10-2014 19:57:12
Yes I bought it from the dealer I need to check the number again but we both looked at it in the parts book. I looked at the parts book again tonight and wrote down the number for every O ring in that assembly. That one sure seems too big. I will look at the old one and compare them tomorrow. I had to use a pick to get the old one out.
This post was edited by R Wyler at 20:03:55 06/10/14.
big orange
06-13-2014 10:02:00
 Re: Gleaner L hyd valve in reply to R Wyler, 06-10-2014 20:02:27
Make some jumper wires and reconnect to functions you know work, , like try the auger swing on header lift, see if they function, and try both switches, could be possible to have shorted the switches also.
R Wyler
06-15-2014 20:01:54
 Re: Gleaner L hyd valve in reply to big orange, 06-13-2014 10:02:00
I will remember that. I got it to working again. I found out that there is a groove for that O ring. I also removed a couple pieces from another O ring in there so there were to I rings inside the body for some reason.
I installed the new one and still no change. Then I pulled it apart again and discovered the poppet was not moving freely. I had put the wrong O ring on it and managed found that it takes the real small ones in that kit. They are difficult to get onto the poppet.
Now it all works and the leak is fixed.
