The 45's unload auger is now long enough!
wilamayb
We had the auger lengthened by 3' which should allow us to hit the center of a gravity box. At the original length the wagon had to be parked in just the right spot to be able to get it over the side.
Now to get rid of the hard, dry rice and cane tires! Those things will beat your eye teeth out!
We had a 45 hi-Lo with those tires on it, was great for our clay
mud. If you could keep the drive belt tight enough you could
drive through water.
I don't want to be the person that has to swing that auger out
now, gonna take some pull, but will work nice for you.
Remember its there when you go past poles, trees, and back
up in a shed......
Paul
