Think this is the spool valve your talking about.
Item Part Number Qty Description
268098M2 1 (A) Valve, 3-Spool, Hydraulic (Cessna 31923Cag)
268098M1 1 (B) Valve, 3-Spool, Hydraulic (Cessna 31923-Aar)
2 1509485M1 2 Plunger, Lock-Out
3 1044486M1 1 Plunger, Unloading
4 1508873M91 5 (C) Poppet Assembly
5 1041771M91 5 Seat Assembly, Lock-Out
6 195868M1 1 (C) "O" Ring (1/2" I.D. x 1/16")
7 1041772M1 5 Spring, Lock-Out
8 1041773M91 3 Plug Assembly, Port Adapter
9 359295X1 1 (C) "O" Ring (5/8" I.D x 3/32")
10 366438X1 1 (C) Ring (41/64" I.D. x 55/64")
11 1051834M91 2 Plug Assembly, Seat Retainer
12 359295X1 1 (C) "O" Ring (5/8" I.D x 3/32")
13 366438X1 1 (C) Ring (41/64" I.D. x 55/64")
14 1041770M91 1 Plug Assembly
15 359295X1 1 (C) "O" Ring (5/8" I.D x 3/32")
16 366438X1 1 (C) Ring (41/64" I.D. x 55/64")
17 1041780M1 3 Bushing, Shoulder (Special)
18 1041777M1 3 Washer (21/64 x 43/64 x 1/16" Special)
19 1041796M1 3 Washer (21/64 x 43/64 x 1/64")
20 1041797M1 3 Washer (21/64 x 43/64 x 3/64")
21 1041779M1 3 Spring, Spool Centering
22 1041778M1 3 Spacer (21/64" I.D. x 29/64" Lg., Split)
23 1055577M1 3 Ring, Retaining (P/N 268098M2)
24 1041776M1 3 Screw, Spool (P/N 268098M1)
25 1055576M1 3 Cap, Work Ports (P/N 268098M2)
26 359363X1 3 Insert, Button (P/N 268098M2)
27 1041775M91 3 Cap Assembly (P/N 268098M1)
28 1 Filter, Cap (P/N 268098M1)
29 1051835M1 6 (C) "O" Ring (1/2" I.D. x 3/32" Thk.)
30 1051836M91 1 Plug Assembly
31 831461M1 1 (C) "O" Ring (9/16" I.D. x 3/32")
32 1021698M1 AR Shim (.015")
1020340M1 AR Shim (.010")
1032707M1 AR Shim (.035")
33 1028423M1 1 Spring
34 1025583M1 1 Poppet
35 278907M1 1 Plate (.020") (To Reduce Header Raise Shock)
36 268142M1 2 Plate, Orifice (.020")
37 268143M1 2 Plate, Orifice (.0135") (Not Used W/Hydrostatic)
38 268144M1 1 Plate, Orifice (.028")
39 268231M1 1 Plate, Orifice (.096")
40 835087M91 2 Plug Assembly (9/16" NF, Thrd.) (Not W/Hydrostatic Only)
41 359293X1 1 (C) "O" Ring (7/16" I.D. x 3/32")
837312M92 1 Kit, Seal Repair (Incl. All Items Marked "C")
All of the [color=red:cc0d27b1bb][u:cc0d27b1bb][/color:cc0d27b1bb]red underlines[color=red:cc0d27b1bb][/u:cc0d27b1bb][/color:cc0d27b1bb] are the plastic poppets we have replaced.
266320M91 1 Valve Assembly, Table Height (See Note A, Page 382)
2 Body (Order 266320M91)
3 1052330M1 1 Plug (3/4 - 16 x 7/8" NF, Hex.)
4 831497M1 2 (A) "O" Ring (41/64" I.D. x 5/64")
5 1052332M1 1 Plug (3/4 - 16 x 7/8" NF, Hex.)
6 1052333M1 1 Spring, Priority Spool
7 1052334M1 1 Disc, Spool and Spring
8 1052331M1 1 Spool, Priority
9 1052338M1 1 Plug (7/8" - 14 x 1" Hex.)
10 835024M1 1 (A) "O" Ring (3/4" I.D. x 3/32")
11 1052337M1 1 (A) Spring
12 196174M1 1 "O" Ring (3/4" I.D. x 1/16")
14 1052336M1 1 Poppet
15 1052335M1 1 Orifice, Flow
16 831533M1 1 (A0 "O" Ring (9/16" I.D. x 1/16")
17 1 Palnut (Order 353438X1 Nut, 1/2" NF, Hex.)
18 1052347M1 1 Cover, Coil
19 1052346M1 1 Coil
20 1052345M91 1 Sleeve Assembly
21 1052408M1 1 Washer (5/16 x 1/2 x 1/16" Thk.)
22 1052344M1 1 Armature, Poppet
24 1052343M1 1 Poppet
25 1052342M1 1 Retainer
26 1052341M1 1 (A) Orifice (.104")
27 371574X1 1 (A) "O" Ring (13/16" I.D. x 1/16" 90 Durometer)
28 359290X1 1 "O" Ring (1/4" I.D. x 1/16")
30 1052340M1 1 Plug, Seal
31 371573X1 1 (A) "O" Ring (1/16" I.D. x 13/64" O.D.)
32 1052339M1 1 (B) Orifice Plug (.028")
33 353691X1 1 Bolt (3/8 x 1" NC, Hex.)
34 375109X1 1 Nut (3/8" NC, Half Hex.)
35 359286X1 1 (A) "O" Ring (1/8"I.D. x 1/16"Thk)
36 1052351M1 1 Plug, Adjusting
37 835024M1 1 (A) "O" Ring (3/4" I.D. x 3/32")
38 1052352M1 1 Plunger, Adjusting
39 1052337M1 1 Spring
40 195868M1 1 (A) "O" Ring (1/2" I.D. x 1/16")
41 1052350M1 1 (A) Retainer, Dashpot
42 196174M1 1 "O" Ring (3/4" I.D. x 1/16")
43 1052348M1 1 Poppet
45 1052349M1 1 Orifice, Flow
46 831533M1 1 "O" Ring (9/16" I.D. x 1/16")
47 1052340M1 1 Plug, Seal
48 371573X1 1 "O" Ring (1/16" I.D. x 13/64" O.D.)
49 1052353M1 1 Orifice Plug (.046")
51 1 Palnut (Order 353438X1 Nut, 1/2" NF, Hex.)
52 1052347M1 1 Cover, Coil
53 1052346M1 1 Coil
54 1052359M91 1 Sleeve Assembly
55 1052408M1 1 Washer (5/16 x 1/2 x 1/16" Thk.)
56 1052358M1 1 Spring, Plug
57 1052356M1 1 Poppet, Orifice
59 1052357M1 1 Armature, Poppet
60 1052355M1 1 Retainer
61 371574X1 1 "O" Ring (13/16" I.D. x 1/16" 90 Durometer)
62 1052354M1 1 Orifice (.040")
63 359290X1 1 (A) "O" Ring (1/4" I.D. x 1/16")
65 1052361M1 1 Nut, Plug
66 835024M1 1 (A) "O" Ring (3/4" I.D. x 3/32")
67 1052360M1 1 Plug
68 1052362M1 1 Spring
69 1052363M1 1 Guide, Spring
70 354465X1 1 Ball (1/4" Dia.)
71 1052364M1 1 (C) Orifice
72 363510X1 1 (A) "O" Ring (1/2" I.D. x 1/16" Thk.)
73 1052337M1 1 Spring
74 1052365M1 1 Spring, Inner
75 1052366M1 1 Poppet, Check Valve
77 364139X1 1 Plug (7/16" NF, Hex. Hollow PT.)
78 831495M1 1 (A) "O" Ring (23/64" I.D. x 5/64")
79 1052358M1 1 Spring, Plug
80 1052368M1 1 Poppet, Check Valve
81 1052370M91 1 Tube Assembly
82 195561M1 2 "O" Ring (3/8" I.D. x 1/16")
83 1052369M1 1 Plate, Valve End
84 353668X1 2 Bolt (1/4 x 7/8" NC, Hex.)
85 353671X1 1 Bolt (1/4 x 1-1/4" NC, Hex.)
86 353441X1 3 Washer (1/4" Lock)
1052776M1 1 Orifice (.020") (To Retard)
837515M91 1 Kit, Seal Repair (Incls. All Items Marked "A")
Just thought I would throw this out there.
1 1 Tank Assembly, Hydraulic (See Page 373)
2 1 Pump Assembly, Hydraulic (See Page 377)
3 844487M1 1 (A) Hose Assembly, Hydraulic, Suction (18-1/2") (Also Used In Hydraulic Reel Drive Accessory)
4 835014M91 1 (A) Connector Assembly (1-5/16"-12)
5 835026M1 1 "O" Ring (1-11/64" I.D. x 7/64")
6 843284M1 1 (B) Hose (1" I.D. x 17-1/4" Long) (Order 842830M1 Hose)
7 244186M1 1 Connector, Pump Inlet
8 835025M1 1 "O" Ring (59/64" I.D. x 7/64")
9 364125X1 1 (C) Clamp, Hose (Grain)
364125X1 2 (C) Clamp, Hose (Rice)
10 835091M91 2 Connector Assembly (9/16" NF Thd.) (Grain)
835091M91 4 Connector Assembly (9/16" NF Thd.) (Rice)
11 359293X1 1 "O" Ring (7/16" I.D. x 3/32")
12 358745X91 1 (D) Tee (7/8 - 14 Adjustable
13 835024M1 1 "O" Ring (3/4" I.D. x 3/32")
14 22833X 1 Cap (7/8 - 14 Str.)
15 268621M1 1 (D) Filter, Oil Pump
16 371615X91 1 (E) Connector Assembly
17 835024M1 1 "O" Ring (3/4" I.D. x 3/32")
18 280432M91 1 (E) Filter Assembly (Order 268621M1 Filter And 358745X91 Tee)
19 1 Housing
20 1052886M1 1 Plug, End
21 371755X1 1 "O" Ring
22 1052887M1 1 Gasket
23 1052888M1 1 Element
24 1052889M1 1 Spring
25 356542X1 1 (E) Tee (7/8 - NF, 2-Way)
29 843751M1 1 (F) Hose Assembly (1/2" I.D. x 18" Lg.)
843750M1 1 (G) Hose Assembly (7/8" - NF x 33" Lg.)
30 364875X91 1 Elbow Assembly (3/4" NF x 7/8" NF, 90 Deg.) (Includes Item 32)
31 835013M91 1 Connector Assembly (7/8" - 14)
32 835024M1 1 "O" Ring (3/4" I.D. x 3/32")
33 1 Valve Assembly (See Page 382)
34 1 (D) Valve, 3-Spool, Hydraulic (See Page 386)
35 358727X91 1 Tee (9/16" NF, 3/8" Tube)
36 831452M1 1 "O" Ring (15/32" I.D. x 5/64")
37 268034M1 1 Tube, Header Valve to Conrol Valve
38 356579X1 1 Cap (9/16 - NF)
39 268032M1 1 Tube, Control Valve to Header Valve
41 355825X1 Connector, Straight (1/2" P.T. x 3/4" NF)
42 268662M1 1 (A) Tube Assembly, Hydraulic (Also Used In Hydraulic Reel Drive Accessory)
43 268046M1 1 (B) Tube, Return Tank to Valve
51 835091M91 4 Connector Assembly (9/16" NF Thd.)
52 359293X1 1 "O" Ring (7/16" I.D. x 3/32")
53 266545M1 1 Tube Assembly, Variable Speed
54 355529X1 2 Union (9/16" NF, Thread)
55 248952M92 2 Tube Assembly, Variable Speed
58 833538M1 1 Hose Assembly
59 832201M1 2 Connector
60 832499M1 1 Hose Assembly
61 1 Cylinder Assembly, Variable Speed (See Page 397)
62 250099M1 1 Yoke, Cylinder
63 248953M92 1 Tube Assembly, Variable Speed
64 266543M1 1 Tube Assembly, Variable Speed
65 835091M91 2 Connector Assembly (9/16" NF Thd.)
66 274592M1 2 Clamp
67 266541M1 1 Tube Assembly, Reel Control
68 356375X1 1 Elbow (9/16" NF, 90 Deg.)
69 250213M92 1 Tube Assembly, Reel Control
70 355830X1 1 Nut (9/16" NF, Hex., Lock)
71 356266X1 1 Union, Bulkhead (9/16" NF)
72 834660M1 1 Hose (3/8")
73 260226M92 1 Tube Assembly (3/8")
74 361312X1 2 Clip
75 834120M91 1 Hose Assembly
76 1026699M92 1 Coupling Assembly, Female Half
77 359297X1 1 "O" Ring (13/16" I.D. x 1/8")
78 1026700M91 1 Coupling Assembly, Male Half
79 260234M1 2 Clamp
80 252788M1 1 Plug, Dust
87 353667X1 AR Bolt (1/4 x 3/4" NC, Hex.)
88 354603X1 AR Bolt (1/4 x 2" NC, Hex.)
89 353441X1 AR Washer (1/4" Lock)
90 355564X1 AR Nut (1/4" NC, Hex.)
91 353685X1 AR Bolt (5/16 x 1-3/4" NC, Hex.)
92 353446X1 AR Washer (5/16" Lock)
93 355565X1 AR Nut (5/16" NC, Hex.)
96 353698X1 AR Bolt (7/16 x 1" NC, Hex.)
97 353757X1 AR Washer (15/32 x 59/64 x 1/16" Flat)
98 353432X1 AR Washer (7/16" Lock)
99 355645X1 AR Nut (7/16" NC, Hex.)
