Kelly in tx
I finished combining my oats, but had to run the carburetor at about half-choke. It is time to remove the carb, clean it out, etc. but access to it is terrible. Gotta go over the muffler, and manifold and there is only a tiny bit of room between the engine and grain tank. I'm thinking of using my angle grinder with a metal cutting blade and making a cut horizontally just below a stiffener in the grain tank. Then cut a rectangular opening for carb. access. My idea is after that to put on a continuous hinge, some sheet metal over the hole, some duct tape, and I should be ready to go. Better ideas? kelly
