I started trying to find a fix for my combine (gleaner k) today, on the left side where the traction and main belt go on is crooked, standing looking at it the right side of the pulley needs to come towards me to get it in line. Someone has adjusted the left side clutch shaft drawbolt up all the way and the right side only about half way, so I loosened the bolts on the clutch shaft support plate and then set the left side drawbolt to the right side setting but I cannot get the support plate to slide back any. do I have to loosen both sides to move one? The original problem was the traction belt was wanting to ride up on the side of the pulley causing it to wear out fast so I need to get everything in line, I'm hoping getting both drawbolts set the same will help in that quest!
