I installed the engine today. It started right up again. I adjusted the timing and it sounds good and it's not smoking. The only issue is I should have replaced the bearing on the drive shaft because it is making some noise. I should be able to get to it from the out side ok.
Thanks to all of you who helped throughout the process. It sure is nice to have it done! I plan on using it summer in wheat, so I will try to post some pics.
Dan B
Dan B
