John Deere 227 picker
Anonymous-0
I have a question about a John Deere 227 corn picker mounted on a IH M tractor I would like to buy are the mounting brackets the same for a IH M as they are for a John Deere A tractor I would like to switch the IH M out for John Deere A sorry I don't have a manual for the picker thanks for any advise Howard
If the picker has universal mounting brackets then most of it will interchange. The rear axle mounting brackets will have some differing small brackets but these can be fabricated. Odds are if the picker is already mounted on an M it has the universal mounts. Look for a hydraulic cylinder to tell you if they are universal. I would highly suggest you get a book. They are readily available. Mike
