Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: Info on pull-type John deere combines? - 96, 106, 6601
rockyridgefarm
12-28-2013 11:39:21
It's not *much* of an issue on my farm because I'm on contour strips. You simply drive on the hay strip next to the corn.
So, a 7721 or a 42 is the only options for pull-types in corn? How much HP is needed to pull a 7721?
jd-tom
01-16-2014 18:25:39
 Re: Info on pull-type John deere combines? - 96, 106, 6601 in reply to rockyridgefarm, 12-28-2013 11:39:21
If you are serious about harvesting corn with a pull-type (not just playing on a few acres), forget about the 42 PT with the 2-row head. Very slow - this machine is smaller than a 45 SP!
Get a 7721 (or 7701) if you can find one. Hope you have large headlands to turn that long rig around!
coonie minnie
12-29-2013 12:03:53
I believe there was also a 7701, offered very briefly before the 7721. The 4 and 5 row heads fit that.
9501s are out there, too, and there may have been corn options for them.
About the only place you saw these critters was in the Dakotas and Canada... and corn in ND was not as popular then as it is now.
65, 96, 106, 6601 would take A LOT of work to make. Not quite like building a 60 crawler, but it wouldn't be a weekend job.
DeltaRed
12-28-2013 16:35:50
Gosh,you need weight as well as Horsepower.So ,125 minimum.4430;1066;1256.....Otherwise,you'ld have the 'tail waggin the dog'
DeltaRed
12-28-2013 18:26:08
 Re: Info on pull-type John deere combines? - 96, 106, 6601 in reply to DeltaRed, 12-28-2013 16:35:50
Sidenote for comparasin:A JD 95Sb has 100 horsepower.
