Gleaner L. Hydraulic control problems
R Wyler
Fired it up a while back on a warm day. The header will lift as it is supposed to. But it will not lower with the header lift switch. However the reel height switch will lower the header as well as lower the reel height simultaneously. What on earth is causing this???? I do have a manual and I am slowly learning about these things but this is real odd. Any ideas???
To check for a stuck solenoid, hold the lever for awhile, activating the solenoid. Feel the solenoids- the one warmer than the others is the stuck one. The magnet heats up trying to move the valve.
Thanks for the help guys. I will check it out when I get time. These things take time to learn I am getting there.
