My Dominator is finally earning its keep.We have had two weeks of on and off rain so I decided to fiddle with my Dominator a little so maybe I could run it in grain sorghum when it finally dries off(still like around 200 acres).I decided to pull the concave out and put the cover plates back on the concave just like Claas had them. When I got the concave out it turns out the leading edges on all the concave bars were rounded off a lot worse than I thought they were.I spent all day one day welding up the leading edge on all the bars and grinding them back to a square edge keeping everything straight with a machined straight edge to go by.I put the five cover plates back on the concave with the levers on the side to engage and disengage them and it really paid off.We started back Thursday and it is a totally different combine.Welding up the concave made a huge difference in the threshing and now I am able to run my cyl as slow as it will go and completely thresh all the heads.When I started back it was still loosing a few pods of seed out the back so I closed all five cover plates and the pods disappeared but it started cracking the grain pretty bad.I then left the front two closed and opened the three rear ones and it is doing a beautiful job now with hardly any cracked grain and virtuall nothing giong out the back.I know some of you will think I am crazy for welding up my concave instead of buying a new one but I didnt want to spend big money on a new concave until I knew it would fix the combines problem.I used a regular welding wire so we will see how long it lasts.If you are having threshing problems take a close look at your concave to see if the edges are rounded any and that may be your problem.I checked this one and didnt think that little bit of wear would make that much difference but boy was I wrong.Rain is forecasted for us again today but when we start back I am going to start snapping some pics again.The row crop heads are really earning thier keep in sorghum this year.Some places in the fields are 100% down and the heads are doing a beautiful job of picking it up off the ground.
