Have any of you ever ran cover plates(some call them block off or threshing plates)on a conventional combine concave?I'm not talking about cylinder filler plates but plates that actually block off part of the concave.I put a J.D. row crop head on my Dominator 76 to cut sorghum with and it is about to drive me crazy.I have ALWAYS been able to set my Fords to thresh and clean as good as you could ask for but the 76 has whipped me.The heads of the sorghum is still tight running around 17.5% but we are cutting it anyway because it is already falling.Both Fords are leaving the ground spotless but the 76 is leaving little dingleberrys with about 3-4 seed behind no matter what.Both the Fords and the 76 are identical inside but the 76 is 10"narrower than the Fords.Both Fords have worn bars and concave but the 76 has like new bars and concave.They are all set basically just alike but I have tried the concave and cly speed on the 76 pretty much every way I can and still have this problem.It acts just like the bars and concave are too aggressive and tearing the pods off before they get threshed.I am at my wits end and am considering blocking off the front third of the concave to prevent them from dropping through.The only way I can get it to even remotely get better is run the cly speed higher but then it is cracking the seed bad.I am beginning to understand what J.D. Seller was talking about when he said they were never a big hit in his area now.I finally parked this one and have been just running the Fords because the 76 is just leaving too much for my taste.This Claas has disappointed me from the word go and it is real close to becoming parts for another Ford.Any thoughts?
