Gleaner f2 service manual
You have a range lever and a shift lever, right? Check that the shift lever isn"t jammed part way into the neutral slot in the middle.
I have the hydro service manual for the f&g I don't know if the f2 is the same or not. Its scanned but its 27megs.
If you give me an email address I will try to email it to you I can probably shrink it in half.
Gramps
Here is a link to where its at. Go into Allis Chalmers combines and you can download it from there. Hope it helps
gramps
poke here
if cable is centering hydro lever then nut came off piston in servo valve. also fork may have split controlling servo
Do you have an parts break down of the servo? Im sure i could handle the repair just like to be ready for any springs that might go flying.
the hose that goes to servo has a brass fitting. it is an orfice was it open? did pin on swash plate arm straddle fork? does swash plate arm move?
