I have a Gleaner E I bought a few years ago (with the stock g226 engine). Everything has worked well on it until this year. While cutting beans, after the engine warms up it would start sputtering like it was starving for gas and I would have to run it ~1/2 choked at full throttle to give it enough (it ran that way but obviously had some power loss). It would run fine at low rpm - idle. Any thoughts what it might be? Should I look at replacing the fuel pump? I do not believe it is the carb since it runs perfect at full throttle when I start it cold...
Any input it greatly appreciated!
Thanks!
Thanks!
