TractorLinks.com
Re: 4WD on older combine----Will it be worth the effort?
oj
08-18-2013 16:25:05
Haley, I will admit i have never done anything like what you are talking about. But, i do wonder how often you would need a driven rear axle... If it would be used every couple of years, and you plan too keep the combine for the foreseeable future, then I would think it would be worth the work and effort in doing the conversion.
Do you know if the 4wd works on the other machine? I know you said the machine doesn't run so it will be sort of hard to test, but it would suck to do all that work to discover you need to spend more money on fixing the 4wd or that parts aren't available.
Just my 2 cents, sorry I can't be more help.
haley
08-18-2013 16:34:42
 Re: 4WD on older combine----Will it be worth the effort? in reply to oj, 08-18-2013 16:25:05
O.J. the axle does work and works real good.The combine it is under still runs but I just havent got it"field ready" yet and it will take too long to do so for corn.The axle will be an easy swap with only three lines,one wire and the center pin that holds it in.I thought about putting it under my hydrostatic 642 but the Dominator has more HP and the hydro pump lines are a lot bigger which means possibly more flow avalible to the rear wheels.
masseypride
08-18-2013 22:26:26
 Re: 4WD on older combine----Will it be worth the effort? in reply to haley, 08-18-2013 16:34:42
I would go ahead and do it Haley. I can not see any reason it will not work.
Masseypride
