TractorLinks.com
Will at All crop 60 manual work for a 66?
Oliver662011
08-15-2013 13:56:54
The question is as simple as the title. Will a All Crop 60 manual apply for a 66 as far as setting up to harvest? Also where do I get one of the handheld tachs, for measuring cylinder speed?
Thanks Mike
TomYaz
08-16-2013 05:56:53
 Re: Will at All crop 60 manual work for a 66? in reply to Oliver662011, 08-15-2013 13:56:54
Manual: Yes
Tach: http://www.mcmaster.com/#tachometers/=o37brm
Brendon-KS
08-16-2013 04:07:09
If it is a late model "Big Bin" version of the 66 the unloader system will be different from what the 60 manual describes but as the others have said the rest of the machine is very similar.
I picked up a nice Stewart Warner hand tach on eBay a number of years ago for a very reasonable price so that might be a place to check. I can tell you from experience that it takes a steady hand to tach an All Crop since they shake around quite a bit when running at speed.
Dick2
08-16-2013 04:17:20
 Re: Will at All crop 60 manual work for a 66? in reply to Brendon-KS, 08-16-2013 04:07:09
AC had a tach attachment available for the All Crop combines. The branch had a whole bunch of those - until the service techs discovered that they would hook right up to the end of the cylinder shaft on the "G" Gleaners.
All they had to do was weld the bracket to the side of the operator platform and attach the flexible shaft to the cylinder.
Brendon-KS
08-16-2013 15:42:45
 Re: Will at All crop 60 manual work for a 66? in reply to Dick2, 08-16-2013 04:17:20
That's interesting; I wasn't aware such a factory attachment existed. I can see how the supply would quickly dry up once other applications were found.
Russ Hamm
08-17-2013 16:33:01
 Re: Will at All crop 60 manual work for a 66? in reply to Brendon-KS, 08-16-2013 15:42:45
My 60 had a factory tach on it, only one iv'e seen.
JMS/.MN
08-15-2013 20:45:54
Manual is the same-0nly difference in the machine is 6 inch wider cut on the header....60 vs 66. Lufkin made a hand tach. No, you can"t have my second one! LOL.
tractormiallis
08-15-2013 20:11:35
Yes, basically the same setup, just a larger machine with the 66, wider cut.
