Was looking for a pull type combine to use for oats, and found a #80 in the local want ads. Went to look at it right away, and brought it home with me, only about a 15 mile drive. Lucked out to find one with a pickup head, since I have a MF#36 swather I use for windrowing.
Looks to be in good shape, was used two years ago on oats. One belt has a deep crack and should be replaced, but all the others look good. No rust in the grain tank, etc. I have 4 acres of oats over alfalfa to test it out on this summer, and plan on running about 10 acres of either oats or barley next year.
Now I can sell the Massey 510 and make some room in the shed. At least the crew has enough of the new roof on the pole barn to cover the #80.
Any suggestions for mounting a jack on the hitch pole? Figuring I would weld on a tube mount for a Bulldog jack. That hitch is HEAVY!
Will a WD pull it, in a windrow cut by a 12' swather? I have a couple of Farmall M's, but no live PTO is a drawback. At least the WD has the hand clutch. I could pull it with the massey 1100, but that seems like overkill. Next step is to order some manuals.
