TractorLinks.com
Re: will a 244 corn head fit jd 40 combine
Doug Shaw
02-20-2013 19:18:29
244 will not work, only a 205 will, which I have an extra one I would sell, think you can get new pumps at jd or napa
cbrown
02-22-2013 09:56:19
 Re: will a 244 corn head fit jd 40 combine in reply to Doug Shaw, 02-20-2013 19:18:29
ive seen 234 and 244 on 45 how did they get them to fit, anyone know what a 244 is worth
Doug Shaw
02-22-2013 10:04:36
 Re: will a 244 corn head fit jd 40 combine in reply to cbrown, 02-22-2013 09:56:19
had a 244 on a 45 once, dont think I had to change anything! should be worth 700-800 in very good shape.
cbrown
02-22-2013 11:19:48
 Re: will a 244 corn head fit jd 40 combine in reply to Doug Shaw, 02-22-2013 10:04:36
i was under the impression the 40 and 45 used the same style hook up am i wrong?
tomstractorsandtoys1
02-22-2013 15:45:51
 Re: will a 244 corn head fit jd 40 combine in reply to cbrown, 02-22-2013 11:19:48
To use a 244 on a 45 you need a quik-tach feederhouse.These were built after production of the 45,55,95 and 105 stopped.The 40 is narrower than a 45 and Deere never built a quik-tach feederhouse for a 40.If you find a 205 cornhead make sure it was on a 40 as some had 45 mountings.
Doug Shaw
02-22-2013 12:07:19
same style maybe but the width is different, 205 will only fit a 40 and 42 pull type I believe
Mike Aylward
02-22-2013 19:15:33
 Re: will a 244 corn head fit jd 40 combine in reply to Doug Shaw, 02-22-2013 12:07:19
Parts were available to put a 205 on a 45 as a lower cost option. The mounting parts are different. Mike
