Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
will a 244 corn head fit jd 40 combine
c brown
02-20-2013 18:56:05
I have a 40 Deere combine and want to know if a 244 corn head will fit what a 244 is worth and also im having trouble with the combine running properly I rebuilt carb but believe the fuel pump is not supplying constant fuel does anyone know where to get rebuild or just put electronic pump on bottom of tank thats in advance
c brown
02-21-2013 13:30:29
 Re: will a 244 corn head fit jd 40 combine in reply to c brown, 02-20-2013 18:56:05
how much is your 205 where are u at how much is a 244 worth also
Doug Shaw
02-21-2013 17:32:54
 Re: will a 244 corn head fit jd 40 combine in reply to c brown, 02-21-2013 13:30:29
Will take 850 for the 205, not really sure on the 244, the 244 should fit several different jd combines thanks Doug, located in central ohio
MLD
02-22-2013 09:37:47
 Re: will a 244 corn head fit jd 40 combine in reply to Doug Shaw, 02-21-2013 17:32:54
Do you know where a 205 is close to Maryland, I've been looking too.
Doug Shaw
02-22-2013 09:57:27
 Re: will a 244 corn head fit jd 40 combine in reply to MLD, 02-22-2013 09:37:47
205 are very scarce, dont know of any others
DeltaRed
02-20-2013 22:48:03
The fuel pumps on those older JDs are problematic.They just dont have the 'stuff' to suck the fuel UP from the tank to carb.Mount the 'lectric pump on the bottom of the tank,'bout 6" to a foot from the sediment bulb."plumb' the gasline clear up to the carb,completely bypassing the 'old' mechanical pump. I have had to replace the fuel pumps on all 4 of the jds I have owned with an electric.If fact,on the last one, I completely removed the pump and covered the hole with a steel plate-never worked better!
Doug Shaw
02-20-2013 19:18:29
244 will not work, only a 205 will, which I have an extra one I would sell, think you can get new pumps at jd or napa
cbrown
02-22-2013 09:56:19
 Re: will a 244 corn head fit jd 40 combine in reply to Doug Shaw, 02-20-2013 19:18:29
ive seen 234 and 244 on 45 how did they get them to fit, anyone know what a 244 is worth
Doug Shaw
02-22-2013 10:04:36
 Re: will a 244 corn head fit jd 40 combine in reply to cbrown, 02-22-2013 09:56:19
had a 244 on a 45 once, dont think I had to change anything! should be worth 700-800 in very good shape.
cbrown
02-22-2013 11:19:48
 Re: will a 244 corn head fit jd 40 combine in reply to Doug Shaw, 02-22-2013 10:04:36
i was under the impression the 40 and 45 used the same style hook up am i wrong?
tomstractorsandtoys1
02-22-2013 15:45:51
 Re: will a 244 corn head fit jd 40 combine in reply to cbrown, 02-22-2013 11:19:48
To use a 244 on a 45 you need a quik-tach feederhouse.These were built after production of the 45,55,95 and 105 stopped.The 40 is narrower than a 45 and Deere never built a quik-tach feederhouse for a 40.If you find a 205 cornhead make sure it was on a 40 as some had 45 mountings.
Doug Shaw
02-22-2013 12:07:19
same style maybe but the width is different, 205 will only fit a 40 and 42 pull type I believe
Mike Aylward
02-22-2013 19:15:33
 Re: will a 244 corn head fit jd 40 combine in reply to Doug Shaw, 02-22-2013 12:07:19
Parts were available to put a 205 on a 45 as a lower cost option. The mounting parts are different. Mike
