45 squareback parts needed
wilamayb
I am needing the engine flywheel plates/flexplates for the main powershaft on a 45 squareback. This is the square flat plates that bolts the main combine powershaft to the engine flywheel. The correct plate would have to come off of a combine with a 180 gas engine. These would be combines with v-belt separator drives.
Part number is H62981.
Thanks for any help!
I'm in Tennessee. The plates are plenty light enough and small enough to be shipped. They weigh less than 10 lbs together. I was really looking for one that was parted out yesterday :)
I have a low acre very sharp 45 with the 180 engine,but it has anti-freeze in the oil.(Former owner did not change anti-freze)The problem is that it is in my shed in MD and I now live in WI.Call Bowie equipment in Tipton IA he has quite a few combines for parts and maybe able to help.563-886-6946 If you would be inteested in a complete 45 I hae a cousin in TN who travels back and forth to MD with a flat trailer.This 45 has never sat outside and never had a cornhead,perfect metal,no cab ad one brand new tire.
(quoted from post at 00:03:16 02/10/13) I am needing the engine flywheel plates/flexplates for the main powershaft on a 45 squareback. This is the square flat plates that bolts the main combine powershaft to the engine flywheel. The correct plate would have to come off of a combine with a 180 gas engine. These would be combines with v-belt separator drives.
I need the same plates. Did you find any?
Do you have any??
