105s gone...
DeltaRed
The 105s sold at auction yesterday.The diesel brought $1150.The new owner is probably going to use the engine to power a tub grinder.The gas corn speacial brought $1600.Never saw the new owner.For that kind of money,it will get used.I am very happy with the results....
Erik,I pd $1000 for the diesel.It needed work.The pd
$1600 for the gas 'cs'.But I 'harvested' the 443
cornhead and two NEW 18.4x26 (12ply) drive tires.The
machine still brought 1600.
"Sometimes you get the bear,sometimes the bear gets
you".I got the bear! :)
I had a feeling you came out well. I would liked to have seen the 105 in the field. I know the situation though, I've added some equipment and have to clean up a little, I've sold some, have more listed and will be taking a few loads to the scrapper. Some of this stuff has been sitting for 4+ years, hate to let it go but I'm not using it and it can't just sit here, may as well work for me.
I think you came out smelling like a rose on that deal. You kept $1000 worth of tires and a $4000 corn head plus you money back on them, Not bad at all! Now if you could only do that every time you would have it made. Bandit
You did fine. I am worried about the guy that is going to use 100hp on a tubgrinder. I have a 425 Cat on mine and it will fall to its knees sometimes. I don't think 100hp is going to be much of a power source. If they only grind light dry hay and all afternoon for a bale he may have a chance.
