Lea Barr
I am looking for drive belts for a 1060 case does anyone have a idea or supplier that they know of that would have these or know where to get them?
what belts are you looking for? some are still available from Case and others aftermarket, if you post what you need I can look up the part numbers for you then we can go from there cnt
What case nutty said plus you can try Applied Industrial Technologies (formerly Bearings Incorporated). Got both variable speed belts, and others, for a I.H. 93 this way. Goodyear belts, and way cheaper than dealer.
JayDee enterprises has any belt you need.If you have a part no.they can cross to their no.I have an interchange book(its free from them),I look up a lot of belts.I buy a lot of belts from them(swathers,combines,balers.....).Their prices are often 50% 0r less than the oem.
Casenutty
I need the drive belt from the drive axle to the idler and also the belt from the idler to the engine,I don't have any numbers on them they are wore off
Take a tape measure and get an outside measurement and measure the width. Go to powertorque.com and find your belt. The one from the engine to the varible is 1 1/4 wide. The variable belt is 1 1/2 wide.
I 2nd DeltaRed,JayDee will have it and will be 1/3 the cost of original most of the time.if they cant cross your # they can match it by measurement.I have used them lots of times.
