Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Belts
Lea barr
01-20-2013 14:04:29
I am looking for drive belts for a 1060 case does anyone have a idea or supplier that they know of that would have these or know where to get them?
haley
01-21-2013 04:01:01
 Re: Belts in reply to Lea barr, 01-20-2013 14:04:29
I 2nd DeltaRed,JayDee will have it and will be 1/3 the cost of original most of the time.if they cant cross your # they can match it by measurement.I have used them lots of times.
casecollectorsc
01-20-2013 20:04:45
Take a tape measure and get an outside measurement and measure the width. Go to powertorque.com and find your belt. The one from the engine to the varible is 1 1/4 wide. The variable belt is 1 1/2 wide.
Lea barr
01-20-2013 19:18:49
Casenutty
I need the drive belt from the drive axle to the idler and also the belt from the idler to the engine,I don't have any numbers on them they are wore off
Case Nutty 1660
01-20-2013 20:09:06
 Re: Belts in reply to Lea barr, 01-20-2013 19:18:49
engine to variable drive is F 12280
lower variable main belt is F 13212
DeltaRed
01-20-2013 18:37:20
JayDee enterprises has any belt you need.If you have a part no.they can cross to their no.I have an interchange book(its free from them),I look up a lot of belts.I buy a lot of belts from them(swathers,combines,balers.....).Their prices are often 50% 0r less than the oem.
Fritz Maurer
01-20-2013 15:05:47
What case nutty said plus you can try Applied Industrial Technologies (formerly Bearings Incorporated). Got both variable speed belts, and others, for a I.H. 93 this way. Goodyear belts, and way cheaper than dealer.
Case Nutty 1660
01-20-2013 15:32:03
 Re: Belts in reply to Fritz Maurer, 01-20-2013 15:05:47
thanks for the other source am always looking good to know cnt
Case Nutty 1660
01-20-2013 14:09:28
what belts are you looking for? some are still available from Case and others aftermarket, if you post what you need I can look up the part numbers for you then we can go from there cnt
Copyright © 1997-2015 Yesterday's Tractor Co.
