Greasing sealed bearings
I use a 1/16" drill bit in a battery drill and drill a hole in the side shield towards the top of the bearing. I use a grease needle (bigger one used to grease the CV joints in a chevy 4x4) and filler up. Clean the hole of grease and put a spot or permatex to seal it up. I have been doing this for 30 years and it will help keep them running for a long time. There are many diffrent sizes of needles that you can get, Any good farm store or parts store should have them. Bandit
Yep,I grease em.Prolongs a bearings life.Grease if it gets 'loose'.then replace it later AFTER harvest
