Yesterday's Tractor Co.
Shop Now View Cart
Re: Strangest things
01-03-2013 05:36:12
I too have an Oliver 7300 that I tried on soybeans. Mine has the auto header height control too. Couldn't get the head low enough to catch the bottom pods. How did you get your head low enough. What did I do wrong on set-up. Thanks
Josh in Pa
01-03-2013 14:50:59
 Re: Strangest things in reply to daled2, 01-03-2013 05:36:12
I have one too. If your head wouldn't go low enough, I bet that the cable from the head to the cab is not adjusted properly. There are some dimensions in the book. If it is set right, the knob in the cab can be turned to adjust the height of the platform. It will cut pretty close, but doesn't feed real well sometimes.
01-03-2013 10:29:29
If your machine has the helper lift springs on cylinders to lift head, they may be set up to tight to let the head go down.
