TractorLinks.com
Re: Vertical auger / unload elbow on 1420 combine
mike french
01-02-2013 13:23:27
The elbow is the same, get one from newer combine as they have thicker ring
IHMANKY
01-03-2013 06:58:43
 Re: Vertical auger / unload elbow on 1420 combine in reply to mike french, 01-02-2013 13:23:27
Wear is not my big issue, mine *may* be twisted somewhere due to *maybe* pulling in the shed with the auger out one day when it was raining. Made several adjustments but still can't get it to swing out far enough to see it out the window, have to lean way forward and look way back. Also, stress cracked the tab the swing cylinder mounts on, I was at work when Dad noticed the crack, instead of waiting he called the local service truck based mechanic who proceeded to weld it up. Along with both the upper and lower flange. Took me an hour with a torch to get it free where it would turn and then I had to build it back up enough to remount what little tab I have. Made it through 400 acres though. Have to replace before next season, and pretty sure the lower tube is twisted some. Can you get a new elbow without gears or is that the way it comes?
fixerupper
01-03-2013 20:34:44
 Re: Vertical auger / unload elbow on 1420 combine in reply to IHMANKY, 01-03-2013 06:58:43
You're gonna have to replace everything that might be twisted or bent to get the auger working right and running smooth again. If the lower auger is twisted just a tweek the flighting won't be centered and the top bevel gears won't line up quite right and the auger won't swing right.BTDT! How is the vertical tube and flighting? You can get a couple thousand wrapped up in an unload auger so fast it'll make your head spin. The auger is the most fragile part of those machines. Jim
1968 403
01-03-2013 13:04:10
make sure the rivets around the bottom inside of the elbow are good. the elbows are all the same from a 1420 to a 2388.
