TractorLinks.com
Re: case 1060/1160 parts
Case Nutty 1660
12-25-2012 07:01:27
Delta I believe has the right number for the feeder chain, as to the floor tin I think you will have a very hard time finding any NOS or reproduction stock, I will assume you are working on a grain hdr as you asked for floor tin, keep this in mind 1000/1010 hdrs will all work and there are a lot of these out there, only differance is the 1000 hdrs have a different carrier yoke size so these will have to be changed out if you intend to use a 1000 hdr, also the 1160 uses a #80 drive chain unlike the others that use #60 but you can change the drive sproket out no problem I do have NOS floor tin that I could get you measurements from but sorry my sets are not for sale hope this helps we all would like some pics of your purchase/progress if you don't mind, I can check out the chain # also but I know that is correct for my 1660 and I do think the 1000/1160 had the same side chains cnt
casecollectorsc
12-25-2012 07:37:09
 Re: case 1060/1160 parts in reply to Case Nutty 1660, 12-25-2012 07:01:27
I replace the floor tin with 20ga. stainless. Only have to do it once that way. 20ga. stainless is as strong as the 18ga original but easier to work with.
Case Nutty 1660
12-25-2012 09:42:09
 Re: case 1060/1160 parts in reply to casecollectorsc, 12-25-2012 07:37:09
thats a very good point!! thanks cnt
