Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: Moving the New Holland Combine
JMS/.MN
12-22-2012 16:37:07
I built a similar tow hitch to pull an M2 behind a tractor, but took off the power steering cyl and made a drag link to attach the steering to the hitch. Follows perfectly.
c leddy
12-22-2012 17:33:00
 Re: Moving the New Holland Combine in reply to JMS/.MN, 12-22-2012 16:37:07
Monday after getting the head up I pulled this Combine out of a lean-to building built on a back of a barn, down a slight slope around the corner up to the front with a WD Allis Chalmers tractor and found out quickly about the power steering cylinder being solid. The tractor turned but the Combine wanted to go straight and run over me (hitch took a quick twist sideways)There wasn't much to do but keep going and the mud helped the back come around and follow. The Allis has a Farmhand loader on it with a protective frame work and 800 lbs of wheel weights on the back so personal danger was minimal but if I knew that machine weighs 11800 lbs plus the heavy Corn head I would of been afraid to try that with the WD. Straightening the tongue/linkage and taking the hydralic hoses off and loose helped on the trailing a lot. It still was awful light in the back and wanted to bounce.
cleddy
