Gleaner C2 Unload Height
Anonymous-0
What is the unload height of a C2 Gleaner? I bought a gravity wagon with 17" wood extensions added on top of the factory metal extensions and its 10' high. My friend has a C II and wants to do some of my custom cutting, I haul it with my wagons. I figure I'll have to take the wood extensions off?
Mine is in my shop right now and there is not enough room to fold out the auger. I will see if I can get it started up in the next few days, move it out a little, unfold the auger and get a measurement for you. Nine degrees outside right now so it may not start right off till it warms up some.
Thats fine, I hate to have you got o a bunch of extra work. I'm mostly just curious so I don't need to know right now.
real short. i can remember having to use a block of wood to get over the side of the box on our first tandem axle truck. i know the combine sat in 1 spot and we moved the truck!
On my CII Gleaner the height measurements of the unloading auger are:
Height from ground surface to opening on bottom of unloading auger - 9 foot 6 inches. Height from ground surface to bottom of spout folded down - 8 foot 9 inches.
