Yesterday's Tractor Co.
Shop Now View Cart
Re: Shop-made header trailer question
Fritz Maurer
12-08-2012 18:39:15
Your primary consideration needs to be the size of the wheels, 8 or 10" at the most. With 15 or 16" wheels it is difficult to deposit the head on the trailer at that high angle, in a way that it can be easily re-attached. You won't have much choice where the "V" is on the trailer, because the combine wheels will hit the trailer before the head reaches the desired offset of the "V". You're going to have overhang of the feeder house, but this can be minimized by having the head as close to the ground as possible. Another problem you're going to have is that unless it is a corn head, it will not support the feeder house unless you have little kick-stands incorporated into your "V" in the vicinity of the feeder house, at or beyond the centerline of the front idler for the feeder chain. If you're planning on roading these trailers, set them up so the feeder house is knocking down mailboxes, not pointing into oncoming traffic.
