| Combines & Harvesters Discussion Forum |
Topic: Re: 3300 combine and morning glories
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| JD Seller
11-30-2012 16:47:20
208.126.196.144
What header are you using??? If it is the old style quick-tach one then they did not retract far enough and there is no adjustment on them for it. Plus the small auger made them wrap easier.If you have a newer 200 series then just take your grinder and grind the leading edge off the steel fingers at a 45 degree angle. Grind them about a 1/2 an inch back. To check if you have ground it enough, roll it to the rear and see if the angle is below the guide. When you get them ground to where the leading edge is below the guide they will not wrap the vines as easy. Almost never. Also a trick to use if you just have a small spot with the vines in it. Cut along the spot with less than half the head. The vines that usually start the wrapping are the ones that are straight out in front of the fingers. The ones drawn in from the sides are usually behind the auger by the time they get to the middle and do not wrap. Also the plastic guides that stuck out so the fingers would retracted back through them did not stop the wrapping the guides them selves would cause it then. Also check and make sure the tin guide holder is tight against the auger on the front side. I usually take and bend them so the leading edge is real tight against the auger as I tighten the retaining bolts. |
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
