Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: Poly auger fingers
JD Seller
11-24-2012 17:11:27
The poly ones are not very good. I run the fiberglass ones that JD/A&I has. They are stiffer and will feed in just like the steel ones. The poly ones tend to bend and not feed in correctly.
Also I found that if you are still using the steel fingers use the JD ones. They are harder and will break rather than bend. I also have took my cut off saw and cut the new fingers thinner at the break point.
Nathaniel Watts
11-24-2012 17:36:06
 Re: Poly auger fingers in reply to JD Seller, 11-24-2012 17:11:27
JDSeller, do you happen to have a part number for them, I can't find it on JDparts.
Copyright © 1997-2015 Yesterday's Tractor Co.
