Yesterday's Tractor Co.
Shop Now View Cart
Re: Hey Haley
11-24-2012 15:40:25
What exactly do I need to remove to get the drive shafts off if I don't need to remove the brake drums? Just the plate behind them and the finals?
11-24-2012 16:30:55
 Re: Hey Haley in reply to Alliscman, 11-24-2012 15:40:25
What I would do is remove both final drives,slide each shaft out as far as it will go,and then unbolt the brackets from the axlehousing that holds the trans in place.The brakes will come out with the trans.Dont forget that there is a spotweld on each trans bracket where it bolts to the axlehousing.The trans can be removed by just taking one final and axleshaft off but in the long run it is easier to take them both off so that you arent fighting with one axle trying to line up the trans on the way back in.
