TractorLinks.com
Re: 1660 broke drive axle
RPM1941
10-31-2012 17:16:33
The axle you are talking about is actually called a final drive. The main axle tube is what it bolts to, both were prone to fail in severe use in rough ground and combines with grain in tank extensions. The final drive was actually first used on 915 all series. The outer Timken cone & cup is the same part number along with the outer seal for 915, 1460/80, 1660/1680. The differences are 80 have wider bull gear & pinion. Last 60/80 had a ratio change in gears (or tooth count).
