Yesterday's Tractor Co.
Shop Now View Cart
Re: 1660 broke drive axle
Bob Bancroft
10-30-2012 09:55:33
When I got a 1660 a fellow told me that with the Cummins engine, inclined auger in the bin, etc. it was late enough the final drives should be OK. So is it assumed a 1660 with IH engine had lighter final drives? I haven't done any research. So far, so good.
Eric in IL
10-30-2012 10:10:57
 Re: 1660 broke drive axle in reply to Bob Bancroft, 10-30-2012 09:55:33
I am also running a 1660, cummins, inclined auger, etc.
Developed a slow oil leak last season on final drive under cab. Enough of a leak that it ran down inside of tire if sitting in one spot for a month or so.
Pulled tire and final this season before harvest. Outer bearing/race were shot.
Bearing and race was $235.
The other final is not leaking but is getting pulled this winter for a look-see.
Bob Bancroft
10-30-2012 10:21:06
 Re: 1660 broke drive axle in reply to Eric in IL, 10-30-2012 10:10:57
Interesting. Haven't had any issue with the axle shaft.(I've had this 3 years now). But the input shaft on the left was leaking a little. When I got into it I found the three capscrews holding the bearing housing in were loose. But they weren't loose! All I could figure was the bolts came loose, and the shims rusted. I started taking out shims to get the bearings tight, then started measuring the shims, and cleaning the rust off them. I was amazed how many thousandths the rust made up. I ended up with all the original shims back in and the bearings just right!
