TractorLinks.com
Re: 1660 broke drive axle
flying belgian
10-30-2012 09:26:43
I just started looking for a good used 1640-1660. Now you are scaring me.
JMS./MN
10-30-2012 14:44:05
 Re: 1660 broke drive axle in reply to flying belgian, 10-30-2012 09:26:43
Good and used is an oxymoron with them. Granted, my ex (no longer farming) neighbor could crack an anvil with a feather, but when he picked up the header (6rn), nothing happened. Drive axle was too busy curving up into the bottom of the combine, under, then through, all the augers that carry threshed corn back to the separator. Dealer wouldn't rent him another to finish- he had to rebuild all that on his own.
Bob Bancroft
10-30-2012 09:55:33
When I got a 1660 a fellow told me that with the Cummins engine, inclined auger in the bin, etc. it was late enough the final drives should be OK. So is it assumed a 1660 with IH engine had lighter final drives? I haven't done any research. So far, so good.
Eric in IL
10-30-2012 10:10:57
 Re: 1660 broke drive axle in reply to Bob Bancroft, 10-30-2012 09:55:33
I am also running a 1660, cummins, inclined auger, etc.
Developed a slow oil leak last season on final drive under cab. Enough of a leak that it ran down inside of tire if sitting in one spot for a month or so.
Pulled tire and final this season before harvest. Outer bearing/race were shot.
Bearing and race was $235.
The other final is not leaking but is getting pulled this winter for a look-see.
Bob Bancroft
10-30-2012 10:21:06
 Re: 1660 broke drive axle in reply to Eric in IL, 10-30-2012 10:10:57
Interesting. Haven't had any issue with the axle shaft.(I've had this 3 years now). But the input shaft on the left was leaking a little. When I got into it I found the three capscrews holding the bearing housing in were loose. But they weren't loose! All I could figure was the bolts came loose, and the shims rusted. I started taking out shims to get the bearings tight, then started measuring the shims, and cleaning the rust off them. I was amazed how many thousandths the rust made up. I ended up with all the original shims back in and the bearings just right!
