steve in wi
Well,I don,t seem to be gaining.adjusted feeder house chains.the rear concave is set at 7/8 and that's as far it will go down,the front I,ve adjust different ways up down.sieves and wind.the only thing I read is that I can,t adjust the cly speed no lower than 450,as what the om says I need different pulley on the belt drive, the one on will raise the rpms when switched so i need a bigger one on top.does anyone run a 715 to help thru this pull thing.I looked at the concave and wear bars,good has filler plates,machine was mostly used on beans before I got it.threashing is a simple concept but yet to make work, frustrating.set up the 6620 and 9500 no problems 715 have a learning curve here,once I figure this out I,ll be OK but wow.90% of the time its something simple so thanks guys.
