Yesterday's Tractor Co.
Shop Now View Cart
F2 Alternator
10-26-2012 18:14:55
I have an F2 gas with a bent alternator bracket. The belt doesn't want to stay on. I've had this machine for two years now, and had no problems last year with the belt staying on. When you look down at it, you can see that the alternator doesn't sit square with the other pulley. Any ideas on why all of a sudden? Thanks in advance. Rob
10-28-2012 21:41:58
 Re: F2 Alternator in reply to ihr190, 10-26-2012 18:14:55
Line it up and it should work fine if tight.
10-27-2012 18:04:48
Allan, I don't even have that little pipe anymore! Just a 3/8 bolt. I will look at it tommorrow. Thanks again.
Allan In NE
10-27-2012 06:21:18
On the bottom bracket, there is a small bushing; tiny "pipe" actually, which tightens and holds the alternator forward.
See if that thing has worn thru and allowing the back of the alternator to drop down a bit.
10-26-2012 19:52:10
Belt in good shape? Make sure there's no excessive play in the water pump pulley.
