Anonymous-0
The belt that drives the fan blades for radiator cooling broke. While replacing the belt I noticed the fan blade had a little wobble so I decided the bearing should be replaced too before the fan goes through the radiator. The fan bearing is pressed into a casting. The shaft coming out of the bearing has a hub pressed onto it. Question??? Does anyone have experience taking out/putting new bearing back into the casting that holds it??? How about taking off/putting on the hub the fan bolts too. Any thing to avoid or helpful hints on taking the bearing apart/reassembly? Thank you. Andy
