Yesterday's Tractor Co.
Shop Now View Cart
Re: 1460 REEL LIFT
Bob Bancroft
10-25-2012 16:24:36
This makes two of you with obvious experience saying basically the same thing. So I just went all through my manual (1991 1660) and I find no such information. One thing I liked very much that AC did was put complete and individual circuit wiring diagrams in their combine books.
Jon Hagen
10-26-2012 11:54:26
 Re: 1460 REEL LIFT in reply to Bob Bancroft, 10-25-2012 16:24:36
The reel circuit uses 1 solenoid to lower the reel, but 2 to raise it.
One solenoid opens the reel passage, another closes the pump return flow passage through the valve stack.
When you lower the reel, the reel solenoid only opens , dumping fluid into the open return flow passage and gravity lowers the reel.
To raise the reel the reel solenoid opens and the return passage solenoid closes, trapping pump pressure in the return passage. Thus high pressure fluid is pushed into the reel passage which extends the cylinders. When you release the reel switch from the "up" position, the reel solenoid closes, locking the reel in position, and the return port opens allowing all pump pressure / flow to return to the hyd tank.
10-26-2012 06:36:09
My 1460 manual has it in, also has individual wiring diagrams for each circuit in the back of the book.
Bob Bancroft
10-26-2012 10:23:30
 Re: 1460 REEL LIFT in reply to tjiniowa, 10-26-2012 06:36:09
The OPERATOR manual?
10-27-2012 05:39:49
 Re: 1460 REEL LIFT in reply to Bob Bancroft, 10-26-2012 10:23:30
yes, operators manual, I will try to get the info on here later today as I am at work right now on break.
Jon Hagen
10-26-2012 15:38:57
I remember the hyd solenoid troubleshoot diagrams, but I think they were in the shop manual ?
My shop manual is out on loan right now so I can't check it.
