Yesterday's Tractor Co.
Shop Now View Cart
Re: 715 grinding corn
todd Hamilton
10-24-2012 18:23:18
Is it dry corn on small cobs? If so open sieves just a little, slow cylinder a little, back air off a little. I never ran a 715 but we typically adjusted the machine every field. Moisture and cob size will affect results every time.
cooney minnie
10-24-2012 18:35:06
 Re: 715 grinding corn in reply to todd Hamilton, 10-24-2012 18:23:18
Usually it is necessary to adjust from field to field, or hybrid to hybrid.
If you are getting a lot of fines, you probably need to look at the rear of the concave setting- are cobs coming out whole? If they are split in two the long way, you need to be open more. If concave is where it needs to be, I'd start by lowering the cylinder speed, but making sure you are still getting all the kernels off the cob.
Adjust the sieves as mentioned above. Lowering fan spped will keep the fines in the machine, but you still have fines.
Keep in mind some corns have softer kernels than others. they require slower cylinder speeds to get the job done. It may be difficult to to get some of them to shell perfectly... especially if it is low test weight, or didn't get ripe before frost.
good luck!
10-24-2012 23:42:38
 Re: 715 grinding corn in reply to cooney minnie, 10-24-2012 18:35:06
Is the quantity of cracked corn not too much? You may be a perfectionist like myself and find out its not too bad when you look at a few of the neighbors total results. Just saying. It sounds like you have done everything I would do in getting it set for shell corn. I always set the cylinder spacing and speed so that you'll just find a stray kernel or two here or there on a cob, and that usually ends up giving the best results in terms of the least amount of cracked corn.
