Yesterday's Tractor Co.
Shop Now View Cart
Re: 1460 new style cross flow fan help please !
10-24-2012 08:31:53
Never seen that issue but have seen them fill up with bean fuzz before. Stainless blades and plastic seperators make it a big static electricity generator. Put a piece of small log chain on the rear axle and let it drag the ground to diffuse the buildup. As for the other what exactly are you finding in the return elevator? With the air flow difference between the old style and new stlye fans, the settings are different than the book will show.
10-24-2012 11:40:00
 Re: 1460 new style cross flow fan help please ! in reply to ihman73, 10-24-2012 08:31:53
If we run corn, there is to much corn leaves, silks etc. If We run beans, pods and dust. Combine is set by the book. Really doesn"t make much difference if we change the settings one way or the other I was wondering since the top of the fan was open, was it dragging this in.
Also I read where there is a cover you can install on the bottom under the combine, mine is open, could it be sucking it in from there as well? Thank you so much for your help.
10-24-2012 20:51:39
 Re: 1460 new style cross flow fan help please ! in reply to TWL, 10-24-2012 11:40:00
The bottom is covered on the 1480 with the cross flow fan. However as mentioned the top isn't. This suggests that the bottom shouldn't be open on your 1460.
