Yesterday's Tractor Co.
Shop Now View Cart
Gleaner M header clutch
Jacob E.
10-15-2012 13:08:45
I have a Gleaner model M combine that I cannot get the electro-magnetic header clutch to disengage. It has power all the way up to the clutch, but the power is what engages the clutch, not disengages it, correct? Is there a spring or anything else in the clutch that would keep it from disengaging? This combine was used last year as well, so it has only been sitting for about a year. Any other ideas as to what could bee frozen or held up?
Thanks for the help.
10-15-2012 22:41:30
 Re: Gleaner M header clutch in reply to Jacob E., 10-15-2012 13:08:45
The clutch is magnetic- needs power to it to engage. No springs. No power= will not pull the halves together. Other poster talks about checking voltage thru switch- there should be none unless switch is engaged.
10-15-2012 14:55:13
Check to see if the rocker switch is cutting power to the clutch when in the off position. Joe
