TractorLinks.com
Re: JD 45 question- Front wheel tread spacing
tomstractorsandtoys1
10-13-2012 11:44:55
Once you narrow it up,you should be fine.You will be a little tight splitting thru the field but after that you will be fine as the stalks do bend a little side to side, so if you are off the row center by 2-4 inches you will have no problem.I had the same problem years ago with my 45 in 38 inch rows planted on hillsides where the planter worked it's way down the hill or the planter driver(Me) got off his mark and planted to close together.We had a 235 head wich is almost the same as a 234, biggest improvement was the screen section in the rear that allowed for a better view of what was happening up front.I finished corn last night with our 95 and 4row 435 head.
Weldon K
10-14-2012 14:51:32
 Re: JD 45 question- Front wheel tread spacing in reply to tomstractorsandtoys1, 10-13-2012 11:44:55
I saw the pictures of your machine on your posting from 10-02-12. Are the front wheels on your 45 set concave out or in? Best I can see in your pictures , they look in. Could you get a measurement of outside of tire to outside of tire for me? Another guy said that when his 45 was set concave in ( narrowest tread ) the tires hit somewhere on the 234 corn head. What do you think?
10-15-2012 12:09:48
 Re: JD 45 question- Front wheel tread spacing in reply to Weldon K, 10-14-2012 14:51:32
That makes me remember when I bought my second 45 and went to put a 235 head on it.I did have to move the wheels to the wide setting for the cornhead(that machine only did small grain before I got it).It still should work in 36inch rows as the side shields will push the corn over some but it might not be a bad idea to move your planter to 38 inch rows next year.
