TractorLinks.com
F3 straw walkers
Doug Wi
10-12-2012 19:28:13
Got a 83 F3 that the straw walkers plug with cobs in corn.the decal on the grain tank by the cab says corn/soy. I read in the archives here that the corn/soy combines have screens on the walkers to prevent this. this one doesn't. looked at an F2 at a auction and it had the screens. Is this something that can be removed and replaced ? Or is my machine mislabeled?. Doesn't seem to bother much. Very little corn on the ground . Just such a pain to have to pick all those cobs out before starting in small grains. thanks for any insight on this.
gbs
10-13-2012 19:37:26
 Re: F3 straw walkers in reply to Doug Wi, 10-12-2012 19:28:13
our's was doing the same thing with the cobs hanging in the walker holes i couldn't find any info on the wire inserts ,two off the walkers needed repairs when i remove them i saw what was left of the wires ,they were about 3/16 in diameter run the length of the walker down the center of the over size opening in the walker spaced apart in at least 6 places with a piece of the same rod welded across them, held in place by a spring steel wire clips,i bought some rods from the welding shop welded spacers across them, then tied then to the walkers with re-bar ties,we don't remove them to harvest other crops ,don't know what the purpose was for such large openings in the walkers to start with
Tim(nj)
10-13-2012 06:16:56
The screens can be removed. My K2 uses the same walkers (just 1 less in width). Shoup used to sell aftermarket walkers for these machines, and somewhere along the way, my K2 got one of them. That one has perforated lips in a piece of sheet metal instead of grating, and doesn't need a screen to keep cobs out. I wish I could find 2 more of them.
JDseller
10-12-2012 19:45:05
Check your operators manual. Some of them had rods or screens that you added in corn depending on your straw walker. Also if your combine manual does not show it check your corn head manual. Gleaner was bad about putting the combine stuff in the header manual for each crop.
Also there are three different straw walkers that I have seen for the F series combines.
